All over the highway =(
it is always a good rule to torque control arm bolts with the weight of the jeep on the ground and required if you still have bonded rubber bushings to prevent preloading them. on kits that have new control arms and with spherical joints, it's not as critical to do as there would be no preload.
You also went to bigger tires. Having taller sidewalls will allow more squish and less stability as well.
Sounds like you might have another issue too, but it will still be there somewhat from this.
