Am I missing anything?
Old Mar 6, 2012 | 10:58 AM
Jason Moore's Avatar
Default Am I missing anything?
So I am taking the leap. I bought a 2010 JK Unlimited Sport two weeks ago and I am going to put a lift on it with new tires.
I went with the 2.5" Teraflex lift with shock adaptors.
spidertrax 1.5" spacers.
Kelly TSR LT315/70R17 SAFARI TSR LR-D BSL.
I am planning on getting a superschipsprogrammer
Is there anything that I need that I am forgetting. I am going to use the stock wheels and paint them.
Old Mar 6, 2012 | 11:00 AM
FoxRacingJMC's Avatar
Yea, your dignity after you go broke from all the mods
Old Mar 6, 2012 | 11:06 AM
Work in Progress - JK's Avatar
If you are going to add larger tires on it now or soon, I would check into the cost of tires on smaller rims that have the correct back-spacing; instead of spacers and the cost of tires on the larger (factory) rims. I did the math when I put KM2's on 15" alloys and came out within $60 (I think) to adding spacers and the more expensive tire sized KM2's on factory rims.
Old Mar 6, 2012 | 11:13 AM
TexasT's Avatar
Have to agree with FoxRacingJMC!
Old Mar 6, 2012 | 11:50 AM
Xodius's Avatar
hmm...15"ers huh. I thought about it a little here. Mine still has nearly new tires but I was thinking of dropping to 16's. I didn't think the 15's would give enough caliper clearance.
Old Mar 6, 2012 | 11:55 AM
CPC1's Avatar
Not sure if 315's wouldn't rub up front with only 1.5" spacers.
I have 285's with 1.5" spacers and Im very close to rubbing at full turn.
Like the above post mentionned if you wanna run tires as wide as 315's I would consider aftermarket rims with proper backspacing 4.5 or less.
Old Mar 6, 2012 | 11:59 AM
Caliper clearance is not a problem with alloys, why I said 15" alloys, as they would be with steel rims - steel rims are welded and not all the welds are exactly the same, so yes they can rub, but after two years of some hard wheelin' mine have never. There is a post on here from the Discount Tire guy pointing out the cost and difference of a 15" tire vs a 17" tire and spacer.
