Another consideration with Rock Hard rear bumper - vehicle length
Installed my Rock hard rear bumper/tire carrier this weekend and discovered something I hadn't thought about. This bumper adds about 9 inches to the overall vehicle length by placing the tire farther out from the tailgate. The Rock hard moves the tire farther out than most aftermarket bumpers because it spaces the tire out enough to fit a highlift jack between the tire and the swingarm. I was pretty tight fitting into my garage before, but I had to move some stuff from in front of the Jeep to be able to pull in far enough to get the garage door to close now.
This is a great bumper and I am very happy with it. Just thought I would mention this consideration as it was something I had not though about before the install.
Another thing to consider when your ass hangs out another 9"....is your departure angle.
When you are climbing a steep ledge, etc...the butt will be more likley to hit as you go up in front/it's pivoted down in back, etc.
And coming down off of ledges, etc.
Its why I like bumpers that fit tighter to the body....for approach and departure.
BTW, even if it is 9" longer, it doesn't matter. 1/4" steel's not going to show much if you bump into anything
I've got the RockHard rear bumper and I can certainly attest that you'll have ABSOLUTELY no problem w/departure angle... Just because the tire is 9" further out (if that is the case) doesn't mean your departure angle is worse... you can't forget about the fact that the RockHard puts your tire vertically up MUCH higher (as seer1 mentioned). So the end result is GREAT departure angle. In fact that was one of the reasons I personally went with RockHard (asside from it being built sturdy as hell). You won't have an issue w/departure angle w/this bumper
I agree that I should have no problem with departure angle, as the tire is up plenty high. The only problem I had was with overall length and fitting into the garage.
BTW... I am truly impressed with this bumper. It is one of the sturdiest/ best built bumpers I have ever seen. The powdercoat was perfect, the welds were neat and clean, the holes were all drilled in exactly the right spots, and it fits extremely well.
Kudos to RockHard 4x4.
Paul
Paul
Explain how the departure angle is NOT affected by increasing the rear overhang by 9"?
Do you mean that where you wheel, you have not had a problem, or that there is something magical about the bumper that makes it miss the ground?
IE: Slide a piece of plywood against the rear tires on the ground, then raise it as high as possible on the rear end of the plywood, until it hits something on the jeep....that's the rear departure angle.
Someone w/o the longer bumper protrusion do the same thing.
Compare.
Pretty much, that's all we need to do...any volunteers?
Compare.
Compare.
Compare.
Here's the only photos I have... hope that helps... The tire may come into contact first (before the bumper), but since the tire is sitting upwards so much more than stock, the departure angle of the RockHard setup is much better than stock.
OK, so the magic is in the fact that its mounted higher than the stock position...so the bumper is at stock protrusion...no increase in over hang...and the tire alone protrudes further, but, from such a great height as to not be what could hit when the rear end is pivoted down as the front climbs, or, could catch on a ledge on the way down, etc.
Gotcha.
The pics helped...I did a quickie departure angle measurement off a pic, looks to be roughly 45 degrees, and about the same for the rear bumper's bottom as the tire....and the ledge would have to be pretty tall to have a problem coming down off it.
IIRC, the OEM departure angle is about 37-38 degrees or so....the pic jeep has a 4" lift and larger tires...and improved the angle less than 10 degrees over the OEM spec. At least its better, and not worse.
Gotcha.
