Another DIY Swaybar disconnect idea
Old Jun 23, 2012 | 11:21 AM
husker_fan's Avatar
Default Another DIY Swaybar disconnect idea
While underneath the JK unbolting the swaybar links to see how long it will take me out on the trail I had an idea.
Rather than removing or un-bolting the links I kept them connected and did something with the swaybar itself.
Here's the idea:
Remove the sway bar and cut it in half.
Sleeve the two halfs together about 6-8 inches on each side, so about a one foot piece of tube to sleeve with.
Drill a hole on each side of the cut through the sleeve and sway bar.
One side put a bolt to hold the sleeve in place.
Otherside put a removable pin.
Re-install everything that you took off.
When you get to the trail, remove the one pin and your done.
With the pin removed there should be good articulation in theory.
Does that make sense or am I crazy?
Old Jun 23, 2012 | 11:29 AM
Firelyle's Avatar
I don't know.....cutting the swaybar just seems.....wrong??! Just my .02.
Old Jun 23, 2012 | 02:50 PM
isolated1523's Avatar
Makes perfect "sense" and would probably work exactly how you're thinking...until you went to re-connect. Getting both of your tires to sit in exactly the same position as where they are when you drill the hole could be pretty tricky i would think. But other than that, no real reason that i could see that it wouldnt work.
-Adam
Old Jun 23, 2012 | 03:05 PM
Tonka_yellow's Avatar
X2 about lining those sides back up.
Old Jun 23, 2012 | 03:06 PM
dinojeep's Avatar
Um, that seems like a lot of work.
JE8154's Avatar
Here's an idea... spend $150 and get some jks quick disconnects and call it a day. Pull 4 pins and you're disconnected. Doing all that to your sway bar sounds completely unnecessary.
Old Jun 23, 2012 | 03:07 PM
EzK's Avatar
EzK
That's basically what a rubicon does. Might be hard in the pins and a sob to drill through the bar.
Old Jun 23, 2012 | 07:47 PM
husker_fan's Avatar
Well it was a thought, just trying to think outside of the box. Wasn't really planning on doing it, but thought I would put it out there in case another idea could be sprouted from it.
and apparently I should have put a disclaimer in the beginning in regards to suggesting JKS or anything similar, I'm aware of them, thanks.
Old Jun 23, 2012 | 08:15 PM
Quentin_T's Avatar
I like the idea, but something would have to be done to keep the sway bar from moving left-right. I would think that you'd have to put something to retain it's position on both sides of the frame on either side.
Besides, reconnecting usually requires adjusting the sway bar to reconnect anyway. With this you might have to get a little dirtier underneath to line up the pin.
