Another tire question...
Old May 29, 2009 | 07:00 PM
Bosox5's Avatar
Veteran: Coast Guard
Default Another tire question...
Hey all, so I finally pulled the trigger today and bought (5) Cooper STT TEK3 325/65R18 (35's) and I should have them early next week, question is: these are 13.5 wide...I also bought wheels with 5.0 Backspacing, will I have any issues with rubbing? they are also Load E tire, will the ride be really bad? I will be running this setup with a TF 2.5 Coil w/ shocks. Can't wait till I get everything to put it all together thanks again.
Old May 30, 2009 | 03:04 AM
Bosox5's Avatar
Anyone??? bump!!!
Old May 31, 2009 | 09:24 PM
Bosox5's Avatar
bump!!!!!!!!
Old May 31, 2009 | 09:31 PM
TAMU Jeeper's Avatar
Im far from an expert on the whole backspacing issue but from what ive read in the past, that wide of tire on a wheel with 5.0 backspacing will probably rub, alot of people would recommend 4.5 or less, someone correct me if im wrong and help a brother out also. Maybe you have but try doin a search also, good luck!
Old May 31, 2009 | 09:34 PM
One more thing the ride will be a little stiff with those tires but they are really good tires in my opinion
Old May 31, 2009 | 09:44 PM
Bosox5's Avatar
Hey, thanks! my wheel is also 18x9. I am really hoping it doesnt rub!!
Old Jun 1, 2009 | 02:40 AM
RedneckJeep's Avatar
You can adjust the air pressure for the E range tire, but I'm not sure it'll be enough. That's a 10 ply tire. They are really stiff. I had some on my powerstroke truck and I tried everything and could still feel every bump in the road. Lotsa luck.
