Another Tire/Wheel Question
Does anyone know if 305/70/16 BFG A/Ts will fit a stock X model with no rubbing? And if someone has this combo will you please post a pic or 2.
Thanks in advance!
Thanks in advance!
It might fit OK on a stock X, if you use the right wheels. Definitely not with the stock wheels though, unless you use spacers. You may get some rubbing when steering hard or flexing out. I'd put 3/4" spacers in the front to give you a little extra room and level the Jeep out, if you're going to run 33s. For street driving you'd be OK, with the right offset/backspacing on your wheels.
-E
here's a good link for conversions:
http://www.wscope.com/tire_conversion_chart.htm
According to this chart, 305/70/16 = 32.8/12 with an 8.4" section height
