Any 2dr jeeps with 3" lift and factory drive shaft..?
Old 02-02-2009, 09:43 AM
In5ane's Avatar
Ok, well some of the threads on drive shaft issues have scared me. I have a 2" BB and installed the 4dr springs on my 2dr, which seems to have given me about 3" lift. Mine is a 2dr auto, so I've been a little worried. I thought about just taking the springs back off and installing the oem, but I'm not sure if I need to.
Old 02-02-2009, 09:52 AM
kflash's Avatar
My front started slinging grease at the transfer case within a few miles after my 3" teraflex lift (which is just over 4" on a 2 door). I switched out to the JE Reel OE replacements. Had some vibration issues. Sent back the rear. They said it was a bad u joint. It is now smooth after reinstall.
I ordered mine from Northridge4x4.
Old 02-02-2009, 10:24 AM
NTXJK's Avatar
3.5" here and just added 1" coil spacers up front no issues sor far
Old 02-02-2009, 11:51 AM
yellow08rubicon's Avatar
Just messed mine up this last weekend. 4 in. of lift on front with 11,000 miles on it. I think it hit the skid plate. I never had problems before but I just put some Teraflex shocks on it. They extend longer then the Skyjackers I had on it and I think that was part of the problem.
Old 02-02-2009, 11:56 AM
hyatt147's Avatar
15000 on stock shafts.....4" inch lift
KNOCK ON WOOD
Old 02-02-2009, 01:44 PM
In5ane's Avatar
May be dumb question, but does an offest front axle (after a lift) tend to cause the rubbing issue...or no?
Old 02-02-2009, 03:29 PM
In5ane's Avatar
By rubbing issues, I mean the front drive shaft havig the boot ripped off...
Old 02-02-2009, 03:43 PM
Piginajeep's Avatar
its from the axle drop when flexing, the driveshaft comes down and his the tranny skid
Old 02-02-2009, 03:58 PM
skruffy's Avatar
Default driveshafts...
yup. i got 10.5k miles on the factory's with the lift installed at purchase.
front and back both needed replacing. went with rubicon express. cost about 8 clams with change.
wished i had done it sooner.
as for the vibrations after the new shafts went on, i upgraded my rear control arms. just drover her back from orlando to g'ville in the rain tonite and couldn't be happier!
Old 02-02-2009, 06:43 PM
Rebel Heart's Avatar
The stock ones work great until they don't. Wished I would have at least changed the rear out when I did the lift. Running a FT 3" Ultimate and the rear went out about 350 miles from home. So, I replaced both driveshafts after having to rent a car to get home, then back to get in two weeks.
Quick Reply: Any 2dr jeeps with 3" lift and factory drive shaft..?
