Any feedback for this exhaust is welcome.
Old Nov 13, 2012 | 05:25 AM
Krawlersaur's Avatar
Default Any feedback for this exhaust is welcome.
So i read a write-up somewhere about a guy that did a DIY exhaust. It used the stock pipes, he just cut a section about mid-jeep, welded in a new muffler, and cut off in the back his stock muffler. The link to the muffler is below. Is there any pros/cons to this muffler placement. Or any pros/cons to using stock pipes. After pricing with extras (clamps ect..) I found it to be an $80 exhaust. That a heck of a lot cheaper. Thanks for any info.
Here is the exhaust ( or VERY similar from pics/description he gave) in question.
MagnaFlow Exhaust Part 10416 - Satin Stainless Steel Muffler
-Aaron
Old Nov 13, 2012 | 07:12 AM
c17loadmaster's Avatar
That is basically all the aftermarket catback systems are. Should work just fine. Make sure after you chop the stock muffler out that you extend the tailpipe so you arent breathing fumes
Old Nov 13, 2012 | 07:19 AM
RustysTech's Avatar
Sponsoring Manufacturer
Rusty's Off-Road
Find a turn down pipe and use that on the "back" side of the exhaust.
Old Nov 13, 2012 | 08:05 AM
nmoldie's Avatar
Did that before. Then later on I had some extra change and bought a "real" exhaust system. Should have saved my money for better things. I couldn't tell any difference from each other.
Old Nov 13, 2012 | 09:31 AM
You mean you didnt see a difference from the DIY exhaust and the "real exhaust kit"? Or you didnt see a difference from the DIY and stock?
-Aaron
Old Nov 13, 2012 | 10:17 AM
scholes_76's Avatar
I was also curious if anyone with a 2012/13 has done this yet
Old Nov 13, 2012 | 03:16 PM
1978cj7jk2012's Avatar
As long as you are not worried about your warranty you should be fine using stock pipe. If your like me and keep all your stock parts you change you might want to reconsider. I had a shop make men's completely new system including a resonator delete with a flowmaster super 44 for under 200 and it includes a lifetime warranty and all stainless steel pipe.
Old Nov 13, 2012 | 03:28 PM
Novae21's Avatar
Had mine done for$60 sounds nice looks even better.
Old Nov 13, 2012 | 03:39 PM
Thanks for all the input guys. Gonna go ahead and make the leap.
-Aaron
Old Nov 13, 2012 | 05:12 PM
iheartmopar's Avatar
I spent 40 bucks on mine and it sounds just as good if not better than some $400+ systems. I have the thrush welded and I love the sound of it. Save yourself the money and DIY!
