ANY problems with 16" wheels?
Old Jan 3, 2008 | 08:30 AM
greggradwohl's Avatar
Default ANY problems with 16" wheels?
I know they come stock on some JKs. Yes I did a search, I just want to be thorough.
I am about to get some Crager soft 8 16x8 5in backspacing.
Is there ANY reason to avoid this wheel?
They will be wearing 35x12.50with on a 4 door rubi (3 inch lift).
Old Jan 3, 2008 | 10:33 AM
that's why i went to the dc-1 black 16x8's...lower costing tires.
but wheel selection is limited with 5x5 bolts, not tire selection
Old Jan 3, 2008 | 10:39 AM
Robar's Avatar
I have the Cragar 16x8 D window w/ 5" of bs. They work great. My tires are not that big, but you should be fine with the rim.
Old Jan 3, 2008 | 12:12 PM
muddpuppy01's Avatar
depending on what size tire you put on the jeep you may need a spacer for that backspacing most lift suggust a min of 4.5"
Old Jan 3, 2008 | 12:36 PM
Originally Posted by SDMF
I run 16's.
It appears I am looking at the same wheels you have. Do you have any rubbing issues?
Old Jan 3, 2008 | 12:56 PM
kcpanther's Avatar
where are you getting your crager wheels from
Old Jan 3, 2008 | 01:52 PM
cmh2001's Avatar
Going with 16'' wheels is more attractive as there are more tire options and 16'' tires are cheaper than 17s.
Old Jan 3, 2008 | 02:51 PM
JK Hunter Howdy's Avatar
16's here also. I didn't want 15's because of the clearance issue with the large brake calipers. I know 15's will clear them but not by much. There is a good selection of 16' tires.
Old Jan 4, 2008 | 04:13 PM
Ragin Gage's Avatar
Amen. Better for airing down and crawling too.
