Any problems with my new set up?
Old Mar 3, 2008 | 07:50 AM
IL Jeep's Avatar
Question Any problems with my new set up?
Hey guys I have a 08 Rubicon I'm probaly going with a rubicon express BB lift, I'm planning on sticking with my original rims. The tires I'm thinking about are Super Swamper LTB 34/10.5/17. Will this lift be enough for these tires, do you think I'll experience alot of rubbing. These tires aren't that much wider than original so I was hoping I wouldn't have to do anything else. Also do you guys recommend the rubicon express BB or a different brand. -thanks
Old Mar 3, 2008 | 09:00 AM
Dante's Avatar
With stock wheels, you'll need to remove or modify your front air dam. You may need to add wheel spacers too or you'll rub the lower control arms and sway bar at full lock. As far as the lift hight is concerned you'll be close. I have been running 33x10.3 on stock wheels for a year now. With stock suspension I tried them without and with Spidertrax wheel spacers. Without I rubbed my disconnected sway bar while turning and flexing at the same time. With the spacers I rub the fender flares slightly while turning and flexing, mostly while descending on the trail. I have just added the Rough Country 2.5" lift and I now how no rubbing.
