Any suggestions-teraflex bump stops
Old Dec 26, 2012 | 08:14 PM
MrHooah04's Avatar
Default Any suggestions-teraflex bump stops
Ive all but finished installing my teraflex 2.5" coil kit but ive ran into a snag with my new front bump stop extenders. After a trip to auto zone for some coil compressors I was still unable to put my new teraflex 2.5" coils on over the new bump stop extension...so I put the extender as well as old bump stop inside the spring and continued on.
My question to you all is..I've heard of ways to install the bumpstop even if the coil is already on...how exactly can this be done. I appreciate the help
Old Dec 26, 2012 | 08:28 PM
Topkicker1's Avatar
Press the fatory bumpstop into the TF extention. Rub some KY jelly (no joke) on the end of the extention that goes into the spring perch. Put the loose extention inside the coil and put the coil in place (in the upper tower and on the axle perch). Line up the loose TF extention and slip a 1x4 thru the coil as close as you can to the tip of the bump stop. Jack up the axle and as the spring compresses, it will push the bumpstop into place.
