Anybody running a 50inch light bar and a soft top?
Have one on mine. I don't get any noise out of the top but the light was whistling like a mofo. Just add door edge guard trim to the fins and you're good. One thing I don't like about it was it added a fair amount of resistance and it has affected my gas mileage a mile or two per gallon. If I had to do it all over again I'd just add a 20" bar to the hood or maybe some side work lights. Still may take it off and do that eventually.
I learned the hard way, got pulled for a fix-it ticket, so had to cover them or remove them. Many jeepers don't cover theirs, but light bars are popular now so police is on notice. If you haven't had problems, okay, but it is the law in Cal.
24411. Notwithstanding any other provision of law, a vehicle may be equipped with not more than eight lamps for use as headlamps while the vehicle is operated or driven off the highway. The lamps shall be mounted at a height of not less than 16 inches from the ground, or more than 12 inches above the top of the passenger compartment, at any place between the front of the vehicle and a line lying on a point 40 inches to the rear of the seat occupied by the driver, shall be wired independently of all other lighting circuits, and, whenever the vehicle is operated or driven upon a highway, shall be covered or hooded with an opaque hood or cover, and turned off.
I have a 50" light bar and pillar mounts place it just above my front windshield. I also run a spiderwebshade and while I get the occasional whistle from the light, it doesn't impact the soft top. I have the little rubber pieces wedged between the heat sink flanges.
Having said all that, I would not bother to take my light off, I just would caution new Jeeper's that it may not be all they expected. PS - I don't and won't cover mine unless I get a fix-it ticket, and most po-po around me are busy with other stuff than to pick on Jeepers. I hope I didn't just jinx myself!
He decided against it on another forum but I guess didn't post here.
I have a single row 50". No whistle or noise - just flutter when soft top is on. Drives me nuts!!!!
I'd put a 10" on the bumper and maybe some light cannons on the pillars if I were to do it again.
