Anyone have the single Rancho steering stabilizer?
Old Jul 17, 2012 | 02:05 PM
adammj's Avatar
Default Anyone have the single Rancho steering stabilizer?
I'm looking for a picture of the setup. I followed directions to a T (I thought) but I have some rubbing going on. Can anyone snag me a photo of their Rancho stabilizer?
P.s. I'm talking about the regular, single one (not high clearance). I think it's the RS5000 (Part no. RS-5407)
Old Jul 17, 2012 | 02:21 PM
Markinda909's Avatar
P.s. I'm talking about the regular, single one (not high clearance). I think it's RS-5407.
I had that setup but now run the relocation where it flips it. That problem rings a bell though. Did the mount maybe get pushed out farther?
Old Jul 17, 2012 | 02:26 PM
adammj's Avatar
I'm going to pull the whole thing off and take a look at it tonight. It's actually been on there for over a year now. I wasn't able to figure out the problem at the time so I thought maybe taking a fresh look at it will help.
Since then, rubbing has worn away a nice little chunk of metal on the stabilizer itself. A superficial wound only, however.
I'll probably have to do the same as you - relocate the axle mount.
Old Jul 17, 2012 | 02:30 PM
Was looking thru my pics and didn't have any pre relocation. Good luck.
Old Jul 17, 2012 | 02:49 PM
RGV08JK's Avatar
Having the same problem with my rough country HD SS kit. Let me know if you come up with anything
Old Jul 17, 2012 | 03:43 PM
keithvegas's Avatar
The high steer kit requires a minimum 2" lift. I may be wrong but yours looks stock height.
Old Jul 17, 2012 | 04:29 PM
RGV08JK's Avatar
I've only had the jeep for about a month now and I was under the impression that it had atleast a 2" budget boost. Im riding on 33's with room to spare
Old Jul 17, 2012 | 04:47 PM
keithvegas's Avatar
You don't have enough lift to clear your drag link so any flex jams it into your steering stabilizers. You need taller coils or put your stabilizer back to stock.
As for the OP, is your tie rod bent at all? I'm guessing you had no problems with the stock stabilizer but a bent rod, even a little could jam up things. Maybe pics would help if you can post some.
Old Jul 17, 2012 | 05:56 PM
GarrettPatton's Avatar
I have a RS5418, give me a bit and I'll go snap a pick for you
Old Jul 17, 2012 | 05:59 PM
Ok here is my setup....
