Anyone here have a JS Alternator??
the smaller pulley makes me wonder if there is a difference in the alternator at all, a smaller pulley makes it spin faster, making more electricity, just like a generator, the faster it goes the more juice comes out, if you put a smaller pulley on the factory alternator it would put out more at a set engine rpm than it did with the larger pulley at the same engine rpm
That's great news. I did respond back after you commented on my post earlier but don't know where it ended up. Did not realize your situation completely and real glad that homegrown product was backed up by the company. Hope it all works out great and sounds like you need some serious electrical capacity there.
Belt length doesn’t make any difference, but a smaller pulley increases alternator speed at idle and on up to a point where the voltage regulator holds it from overcharging, back in the pre computer days we used to do a lot with pulley size, from alternators, power steering with larger tires helped a lot at low speeds, I’m sure they do more internally, but pulley size can do a lot for low engine rpm and higher output on alternator
https://alternatorparts.com/alternator-pulley-size.html
This link gives you a better way to play with the numbers, just saying the crank pulley is 8 inches and the alternator is 2 inches, at 1000 rpm engine speed, the alternator is spinning 4000 rpm, a quarter of an inch smaller pulley on the alternator changes the speed to 4571 rpm, that 571 increase at 1000 rpm.
just an example, a small size difference can make a good difference.
not saying anything against the alternator company or what they produce or their customer service, just saying that the smaller pulley helps on what the overall product does and we used to play around with different pulley sizes that can make a difference
https://www.blocklayer.com/pulley-belteng.aspx
