Anyone running 2" backspacing?
Old Oct 2, 2013 | 06:30 AM
liquidg's Avatar
Default Anyone running 2" backspacing?
Putting on some spyderlock bead locks onto my standard width dynatrac axels today and wondering if I should keep my spidertrax wheel spacers. The spyderlocks have 3.5" of backspacing and the wheel spacers are 1.5". Thinking it will give me a wider wheel base and keep my tires from contacting the coilovers. Any pictures or first hand experience would be much appreciated.
Old Oct 2, 2013 | 06:41 AM
kh202's Avatar
I think that might be a bit overkill and put a lot of unneeded stress on bearings and such (same as if you had wheels with 2" of BS). I'd put the wheels on without the spacers and test it out first. If you do need additional clearance, i'd get some smaller spacers.
Old Oct 2, 2013 | 06:55 AM
planman's Avatar
Forum Tech Advisor
3.5" backspacing is plenty on tires up to about 37s with stock axle width.
You wouldn't need 2" net backspacing unless you were running 42s or larger, but if you are running tires that big on stock width axles, backspacing is the least of your problems.
Old Oct 2, 2013 | 08:33 AM
karls's Avatar
I have a net backspace of 2" .....though I don't have a ton of weight like the spyderlocks and surely the large tires that would go on them. My width and stance is to keep out of the other ruts on the beach- seems to work well for me. Oh yes, I have stock u's and bj's at 87k miles now with this setup.
2" of BS will keep everything pretty well out and away from anything under the jeep
Old Oct 2, 2013 | 08:36 AM
JE8154's Avatar
Originally Posted by karls
I have a net backspace of 2" .....though I don't have a ton of weight like the spyderlocks and surely the large tires that would go on them. My width and stance is to keep out of the other ruts on the beach- seems to work well for me. Oh yes, I have stock u's and bj's at 87k miles now with this setup. 2" of BS will keep everything pretty well out and away from anything under the jeep
are those 29's, looks sickly
Old Oct 2, 2013 | 08:54 AM
DesertJeep's Avatar
Really? The guy's trying to help another guy out with some information, and trashing on his rig seems appropriate?
Old Oct 2, 2013 | 09:01 AM
karls's Avatar
Close.....31's. Thanks for the compliment
Sent from my DROID4 using Tapatalk 4
Old Oct 2, 2013 | 03:31 PM
liquidg's Avatar
I am running 37" Trail Grapplers. I have seen people hit the King Coilovers on full flex with 37's so I didn't know if I should go this route or not.
Old Oct 2, 2013 | 04:03 PM
planman's Avatar
Forum Tech Advisor
You should be fine with 3.5".
