Anyone running a oil pressure gauge on 3.6L?
Old Aug 28, 2014 | 12:43 PM
Vladimer's Avatar
Default Anyone running a oil pressure gauge on 3.6L?
I've been looking around as I have a switch panel with a round hole for a gauge... but no gauge to put into it. Figured the most suited would be an oil pressure gauge as if that goes, well it can be a bad failure...
On the 3.8L it was as simple as a sandwhich plate, but the 3.6L has a canister filter. Looked around without much success as I read someone drilled some part of the block or pan after taking apart a fair bit to reach this area, but details were sparse.
Anyone get one running?
Old Aug 28, 2014 | 08:00 PM
GoBig's Avatar
Just run aeroforce gauge (s)...I do and it reads oil pressure on my 2012.
Old Aug 29, 2014 | 02:36 AM
14Sport's Avatar
x2. And much, much more.
Name:	BBK 025 (Small).JPG
Old Aug 30, 2014 | 06:40 AM
Vladimer's Avatar
Oh cool, that would totally work. Thanks guys!
14Sport, did you use the 9' cable? Looks like yours is above the windshield which is where I would be putting mine. Unless it only has just a couple wires that can be spliced to extend.
Old Aug 30, 2014 | 07:26 AM
14Sport's Avatar
Yeah I got the long cord and just looped excess under the dash.
Old Aug 30, 2014 | 08:37 AM
GoBig's Avatar
Mines in the A-pillar...dual gauges.
Old Aug 30, 2014 | 02:43 PM
Mschneid's Avatar
Well that sux, my aeroforce POS doesn't read oil pressure, tranny temp or a bunch of other things I would want. How do I get it to work?
Old Aug 30, 2014 | 03:06 PM
14Sport's Avatar
You have to plug it in to the OBD2 port and go through the different options and select the things you want to see.
Here's a link to the manual. You want to go to Chrysler vehicles platform 5 (Jeep Wrangler). Page 27 for the different sensors that can be monitored.
http://aeroforcetech.com/files/Inter...AL_rev_3_8.pdf
Old Aug 30, 2014 | 05:01 PM
John_fender's Avatar
If you are not getting oil temp, trans temp ect. on your gauge, you may have older firmware and will need to send
it in to have it updated, I believe it is free except for shipping.
Old Aug 31, 2014 | 06:52 AM
Mschneid's Avatar
Platform 5 is where I screwed up, thanks. I see Trans TMP V6/R8 but it only reads what the last battery volts reads.
Maybe like John_fender says it may need re-flashed.
I don't have oil pressure option. Do I need the analog inputs?
