Anyone selling atx slab beadlock with RADS installed
Does somebody knows if there is anyone selling atz slab beadlocks with the RADS (Rapid Air Down valve System) pre installed? (similar of what spyderlcks offers as an option).
May be one of our vendors can chip in?
A review I recently read, said from 35 to 10 PSI in 38 seconds. You should be ready to keep your TPMS sensors since they are in addition to the regular valve, so that you'll have valve + RADS in each wheel (unless, there is a reason I do not know for which you lose your tpms sensor anyway when you use a beadlock)
I'm thinking if you want to keep your sensors, you could tap another hole on the opposite side of the regular valve with sensor and install the RAD system. I wonder if this is the route NR 4 x4 will do to get those RADs on the rims.
