Anyone using Champion beadlocks?
What tire are you using them with? What's been your experience?
I have their Baja wheel with C3FM ring and 35" LTB tires. There's a 10 degree angle built into the bolt holes to compensate for the flex when you tighten down the ring, but with the LTB's 1" bead, I'm getting about 20 degrees of flex. I'll be speaking with the manufacturer a bit later about this, but wondered if anyone else has had similar issues...
Thanks,
js.
Thanks,
js.
