Anyone using a Hand Throttle??
Old Feb 8, 2008 | 04:26 AM
The Joker's Avatar
Default Anyone using a Hand Throttle??
anyone using one of these??
how difficult is the install and do you like it?
http://www.quadratec.com/products/RE1000.htm
Old Feb 8, 2008 | 05:54 AM
wayoflife's Avatar
JK-Forum Founder
Not on my JK but I do have one installed on my TJ. I personally think that using the hand brake does a better job of getting your stick to perform on the trail but the hand throttle can be used to keep the RPM up when winching.
Old Feb 8, 2008 | 06:03 AM
2K1TJ's Avatar
I'm not sure if this will work with the drive-by-wire system. I haven't really looked at the throttle body to see. I'm not sure if there's a physical link to the throttle body or just an electrical connection.
Anybody know?
Old Feb 8, 2008 | 06:34 AM
wayoflife's Avatar
JK-Forum Founder
Anybody know?
LOL!!! Now that you mention it, I don't think there is a physical link to the throttle body.
Old Feb 8, 2008 | 08:02 AM
quadratec's Avatar
Sponsoring Vendor
JK's are throttle by wire, but I dont see why you could not rig a hand throttle up to lever the throttle pedal it's self. Would server the same function.
Old Feb 8, 2008 | 08:18 AM
The Joker's Avatar
bummer.... I would have LOVED to have one that is a bolt on.....
Old Feb 8, 2008 | 04:40 PM
castor07jk's Avatar
Sounds like you should make one before someone else. Could be your money maker
Old Feb 8, 2008 | 06:35 PM
greasemonkey85's Avatar
how does hand braking work? sorry never been hardcore offroading.
Old Feb 8, 2008 | 09:31 PM
castor07jk's Avatar
you mean hand throttle, when you are on rocks it can be tough not to bounce on the throttle pedal. This causes your jeep to lerch forward so you let off causing it to nose dive,now your back on the throttle because your body shited foward and it repeats. This is more for a stick than a auto.
A hand throttle allows you to pull the throttle to what ever rpm you want the engine to stay at. This makes for a realy smooth crawl.
Old Feb 8, 2008 | 09:55 PM
TEEJ's Avatar
Talking
The other thing the hand throttle does is make it a breeze to get moving again if you had to stop on a steep technical rock crawl, as in, you are placed where you better not roll back at all, you have a manual tranny, and need one foot to work the gas, one foot to hold the brake while stopped, and one foot to work the clutch. (3 feet)
I never had a hand throttle, but some friends did, and liked them...I just used heel/toe technique - I'm used to it.
Hand BRAKING is used to stop your tires from spinning on an open or LSD diff....providing artificial resistance to load both tires with some torque against them, so they can turn at the same speed again...we call it the poor man's locker.
If you have a drive by wire system...and cruise control...perhaps the trick will be a hack to let the cruise control be set for sub-mph speeds, etc.
Or use one of those new fangled programmer thingies to raise the idle speed to what you want it at, etc.
When I had to off road with a blown knee, I used a crutch to work the clutch....which is tough when you're bouncing around, etc....but a mechanical version with a ratcheting bar, etc...could probably be fabricated a la one of those steering wheel/gas pedal security club type things....etc.
