Anyone using a York compressor?
Old Mar 2, 2008 | 11:12 AM
jsmoriss's Avatar
Default Anyone using a York compressor?
Has anyone mounted a York compressor under the hood yet? I need a 4+ CFM at 90+ PSI compressor to run air tools -- the new Warn VTC looks good (8 CFM at 90 PSI!), but I wouldn't know where to mount it. The Kilby York compressor kit mounts under the hood, so that's nice, and it's rated at 4 CFM at 90 PSI at 1200 RPM. Kilby's installation instructions are not that great though - I was hoping someone had done it before and would have some comments on it... :-)
Thanks,
js.
Old Mar 4, 2008 | 05:51 AM
jsmoriss's Avatar
Bump. Anyone?
Old Apr 4, 2008 | 11:15 AM
jsmoriss's Avatar
Anyone using a York compressor yet?
Old Apr 4, 2008 | 11:18 AM
BYU JK's Avatar
Looks like you might be the first. Let us know how it works out.
Old Apr 4, 2008 | 01:34 PM
montejeep01's Avatar
got a York on my tj. kinda high maintenance. would i put on a jk? nope. get 4 portable compressors and air all four up at once. then pocket the rest of money.
Old Apr 4, 2008 | 02:01 PM
Northridge4x4's Avatar
Sponsoring Vendor
If you only need air for tires the powerplant is perfect.
David
Old Apr 4, 2008 | 02:23 PM
Blue's Avatar
David
That seems to be what most people that want oba are doing. I was going to suggest that. I'd hate to give up my AC to make room or sacrifice any hp/tq.
Old Apr 4, 2008 | 03:30 PM
2K1TJ's Avatar
I know the Kilby kits are usually nice (and $$$!), but what about the others?
Old Apr 4, 2008 | 07:20 PM
Littlejon's Avatar
I know that Off Road Only has a York kit, and I know that Ron at Wandering Trail has a nice write up on it. It also doesn't require any re-work of the ac lines. I know that at the moment I am planning on going with AiRock, and so this will be the way I go.
Old Apr 6, 2008 | 06:36 AM
jsmoriss's Avatar
I went with the Off Road Only (aka ORO) kit as well. I like the fact that it mounts on the front, out of the way. Now I'm wondering if I can buy Kilby's bracket seperately and use it to mount a second battery. :-D
js.
