ARB compressor mounting location?
Thanks guys! Just ordered the 2 track minds bracket.
Now the switch, I am thinking to mount them to that A pillar plastic, I don't have those ARB switches yet, but they do look big, hope they will fit in. Same idea as the pic below I borrowed from a forum member.
Can someone please post a direct link to the 2tm compressor mount? I am having trouble finding it on their site..
Actually if anyone has a pic of one installed that would be heaps better as i am deciding if these will fir a right hand drive jeep.
http://stores.ebay.co*/2-Track-Minds-Offroad
I finally figured out the broken link - looks like a simple, quality piece. Does it work with both ARB compressors? Do you really need the larger compressor if it would only be to operate the lockers and occasionally inflate tires?
I believe ARB does not recommend airing up tires with the small compressor.
I installed the ARB under the driver seat and the switch I installed above the
front drivers side dash speaker.. tonnes of space there for the depth of the
switch and wireing and you can run the lines through the drain plug and down..
Hope this helps
Zeb
Hope this helps
Zeb
