ARB compressor mounting location?
I gotta say thanks for this thread, especially ge2's pics. I've been banging my head trying to figure out the stupid wiring for the HO compressor (why is this there, what is that for, where does the locker connect to the tank....). ARB packed the wiring diagram for the non HO compressor (which doesn't show much anyways) and their website has absolutly no info. I finally found a wiring diagram for the HO thanks to google. But those pics finally made it make sense.
This should not be difficult. ARB if you are reading this, INCLUDING INSTRUCTIONS for at least a bare bones install. I've built multi million dollar computer systems but can't figure out how to hook up a stupid pump!
Grumble.
Grumble.
Mounted mine behind the RHS tail light.
Mounted on 1" Neoprene Vibration Dampers
Hose in stock jack location, jack moved to the tub.
Switch mounted near hose as i already have electric lockers (rubi)
We now stock a bracket to mount the compressor under the hood.
It runs $85.
David
Reddavid - If you are still having trouble give me a call I can walk you through the install or get you the correct install instructions.
David
It runs $85.
David
David
Is that the one that mounts right next to the brake master? I was thinking about going with that one but would rather get it from you.
Does anyone have a pic of the "2 Track Minds" one installed? Or the one Northridge Dave is talking about? Are these the same? All I could see on their store/site is pics of the bracket itself.
More pics attached. Hope these help
