ARB compressor vs Viair
Old Oct 6, 2009 | 06:46 PM
jdcjeep's Avatar
Default ARB compressor vs Viair
Any body know how the ARB on-board air compressor that you can mount under the hood compares to the Viair constant duty compressor? I just need it for tire and camping gear inflation, no air lockers. I got the viair, but it wouldn't fit under the hood with the tank. I mounted it inside in back, but I don't like how much room it takes up. So I'm wondering if the ARB performs well inflating tires. Thanks!
Old Oct 6, 2009 | 07:49 PM
Jsr's Avatar
Jsr
Mount the viair compressor behind the right rear tail light, keep it away from the heat of the engine compartment.
Old Oct 6, 2009 | 07:52 PM
wildandwillin's Avatar
The ARB fills up the tires nicely
Old Oct 6, 2009 | 11:04 PM
NGINIER's Avatar
How quickly does it fill up tires? I'm looking into some sort of on board air solution. I was originally just going to go with a tank but if I could save the room in the back that would be nice.
Old Oct 7, 2009 | 06:08 AM
8000ft's Avatar
I picked up a Westward unit from Grainger for 106.00$ and striped off the outer shell and stuck the rest under my drivers seat, it stays warm and dry. It puts out 2.6 cfm. I never under stood the need for a tank in this type of application.It a good unit for occasional use but for heavy duty I would go for one of the others as well.
Old Oct 7, 2009 | 06:41 AM
alim10004's Avatar
I have a VIVAIR on a custom bracket under the hood.
Works fine.
Old Oct 7, 2009 | 06:55 AM
jdcjeep's Avatar
Thanks, jsr. I like your red river tank and evap skid plate. I think I'll get me one of those.
Old Oct 7, 2009 | 06:57 AM
jdcjeep's Avatar
Whoops. I mean river raider air tank and evap skid plate.
Old Oct 13, 2009 | 10:00 AM
CitadelJeep04's Avatar
Did you get yours set up yet behind the tail light? I think I'm going to go this route. I just ordered a kit from Northridge for a much better price than elsewhere... Cant wait!
Old Oct 13, 2009 | 05:29 PM
ricrac12525's Avatar
Default Arb fill time
I have the ARB unit, it took about 3 minutes per tire, I have 34/10:50/17 and they were aired down to 12 psi. hope this helps you
