ARB diff covers trouble with install PLEASE HELP!!!!
Old Oct 26, 2012 | 03:37 PM
charlie4's Avatar
Default ARB diff covers trouble with install PLEASE HELP!!!!
I bought front and rear ARB diff covers for my 2012 JK and just installed the rear 44 and when I went to install the drain plug the magnet hits the casting in the punkin. I havn't tried the front yet 30. Has anyone else run into this? Please help!!! Thanks
Old Oct 26, 2012 | 03:40 PM
keithvegas's Avatar
There should be no clearance issues at all. Is it possible you are trying to use the wrong plug?
Old Oct 26, 2012 | 03:41 PM
4x4chick's Avatar
X 2 On what he said.^^^^^
Old Oct 26, 2012 | 03:43 PM
charlie4's Avatar
Nope its the drain plug for sure. I am not sure what to do with it. If you look in the drain hole the casting comes up about half way up the hole.
Old Oct 26, 2012 | 04:02 PM
keithvegas's Avatar
Might be going in crooked because the magnet is pulling it to the casing otherwise the only thing I can think of is you are installing the 30 cover on the 44 diff mounting it wrong.
Old Oct 26, 2012 | 04:10 PM
weebus's Avatar
Default diff covers
i had front and rear arb diff covers on my 2011 jku with no such problems.i cant imagine it would be different on a 2012. can you post some pics so we might view the problem?
Old Oct 26, 2012 | 04:58 PM
marmot74's Avatar
Installed a ARB cover on my 2012 Rubicon with 44's front and rear last month, no problems.
As one member said, the magnet can push it around a lot and it takes a quick hand to get it on
Old Oct 27, 2012 | 04:12 AM
charlie4's Avatar
I ended up pulling the cover back off and taking a die grinder and taking a small amount of the casting out so the magnet would clear. My luck everybody elses fits but mine. Wasn't really a big deal just made me mad I had to pull the cover back off. Front cover was no problem. Wish I would have got some pictures. Anyway thanks for the help guys
Old Oct 27, 2012 | 09:42 AM
Gman*2007's Avatar
I just installed Black ARB diff covers last weekend on my 2012 JKU with no problems. I guess all is not the same.
