ARB Twin Compressor
Old Feb 28, 2013 | 11:12 AM
jsands's Avatar
Default ARB Twin Compressor
Is anyone running the ARB Twin? If so can you post up some pictures of your install and tell me how you like it.
Old Feb 28, 2013 | 11:19 AM
Northridge4x4's Avatar
Sponsoring Vendor
I dont have any pic's but we install them under the passanger seat and it works really nice.
David
Old Feb 28, 2013 | 12:43 PM
T&ERun's Avatar
Here is a link of how I mounted mine. It's been there for over a year now with no issues. I don't have a cad drawing or anything, sorry. If you know someone that is good with metal they could make you one fairly easy.
https://www.jk-forum.com/forums/modi...ressor-195183/
Oh, and I bought my compressor from Northridge.
Old Feb 28, 2013 | 01:38 PM
jsands's Avatar
David
Do you guys run remote air filters? Do you add air tanks? What is your price on them?
Thanks
Old Feb 28, 2013 | 01:40 PM
jsands's Avatar
Nicely done! I have a 2012 so i don't have the room under the hood. I like the air tank but i fold my seats down too often.
Old Feb 28, 2013 | 05:25 PM
BRUT4CE's Avatar
Former Member
Did mine here and put a cover over it .
Exhausted the breather on the solenoid outside to vent any gear oil vapor out.
If you run lockers off of it vent the solenoid outside, I talked to ARB and gear oil small amount in line is normal. It will spew a smidge when disengaged.
Old Feb 28, 2013 | 06:23 PM
srodholm's Avatar
Just installed mine under the passenger seat on a 2013 JKUR. I ran a hose off the compressor and then split it under the rear seat so I have a quick connect on each side just inside the back doors. I do not run a tank. I have one on my TJ and decided I did not need it for the JK. I just use it for tires so the extra capacity is not necessary.
Old Feb 28, 2013 | 07:04 PM
T&ERun's Avatar
It's a loud compressor IMO. Make sure you'll be ok with the noise inside the cab before you install.
Old Feb 28, 2013 | 08:00 PM
ZERO LIMITZ's Avatar
I bought the rugged ridge dual battery tray and mounted my dual ARB in the extra hole at an angel. Works great, I don't have pics just yet but will post some up soon!!!
