artec font truss ?
Old Apr 25, 2013 | 06:50 PM
kingkat's Avatar
Default artec font truss ?
Im getting ready to order a artec truss for my front rubi axle and need to know if i need the factory height trackbar bracket or raised. I have the RK 3.5 tripple threat lift. Thanks
Old Apr 25, 2013 | 07:40 PM
BuckLisa's Avatar
You don't, but I would order the Artec front stock trac bar bracket that will allow you to raise your steering stabilizer up and it's much stronger than stock. Since you have to weld, might as well do both at same time.
http://www.artecindustries.com/JK-He...et-_p_317.html
Old Apr 26, 2013 | 02:43 AM
BuckLisa's Avatar
To clarify; you can keep your stock trac bar mount and not need to do a drag link flip unless you want to help your steering out to prevent bump steer if you have experienced that at the 3.5 lift. If you haven't keep your stock bracket or get the Artec OEM location mount I talked about in the earlier post.
