ATX Wheel Offset
I'm looking at an ATX #756 Slab wheel for my '13 JK Rubicon but the only offset I am finding is -38mm. Isn't this a bit much? I have a set of 35/12.50/17s to put on them and have a 2 1/2" lift and flat fenders. What are your thoughts about fit and how it will look with that negative offset?
most beadlocks are going to be set up with that kind of offset, with the exceptions being walker evans, hutchinson and AEV.
what flat flares are you running? i have the slabs and used to have bushwacker flats and had a good amount of coverage - have nemesis flares now and the coverage is almost the same.
bushwackers
nemesis
bushwackers
nemesis
I'm running the Bushwackers with stock Rubicon wheels with spacers right now. I've been trying to decide exactly which wheels I want. So many choices but only want to do it once since they are a bit expensive. These 35/12.50/17 Toyo M/Ts look a bit small right now, I hope the 9 inch Slab wheels will make them look a bit larger.
