ATX Wheel Offset
Old Jan 24, 2013 | 04:46 AM
Silverton34's Avatar
Default ATX Wheel Offset
I'm looking at an ATX #756 Slab wheel for my '13 JK Rubicon but the only offset I am finding is -38mm. Isn't this a bit much? I have a set of 35/12.50/17s to put on them and have a 2 1/2" lift and flat fenders. What are your thoughts about fit and how it will look with that negative offset?
Old Jan 24, 2013 | 04:53 AM
2008fx4's Avatar
most beadlocks are going to be set up with that kind of offset, with the exceptions being walker evans, hutchinson and AEV.
what flat flares are you running? i have the slabs and used to have bushwacker flats and had a good amount of coverage - have nemesis flares now and the coverage is almost the same.
bushwackers
nemesis
Old Jan 24, 2013 | 05:39 AM
I'm running the Bushwackers with stock Rubicon wheels with spacers right now. I've been trying to decide exactly which wheels I want. So many choices but only want to do it once since they are a bit expensive. These 35/12.50/17 Toyo M/Ts look a bit small right now, I hope the 9 inch Slab wheels will make them look a bit larger.
