Automatic Trans Shift handle replacement
Old Mar 14, 2011 | 05:27 PM
BigMoe's Avatar
Default Automatic Trans Shift handle replacement
Has any one replace the oem A/T shift handle with a custom one, if so how?
Old Mar 14, 2011 | 05:42 PM
rubi08unlimited's Avatar
I have the drake billet one i got for christmas and would like to hear some input on this as well.
Old Mar 14, 2011 | 05:44 PM
greenenvey's Avatar
nice!! are you going to get the drake hood hold downs to go with it?
Old Mar 14, 2011 | 05:50 PM
JacKed 8's Avatar
i replaced all my shift knobs with the Drake models, including the e-brake handle. The actual shifter is easy...it's the 4-wheel shifter that's tough....
Old Mar 14, 2011 | 06:09 PM
BigMoe's Avatar
Wondering how to use an aftermarket shifter andif the park interlock would work on a custom shifter.
Old Mar 14, 2011 | 06:32 PM
BigMoe's Avatar
What I was trying to say was, has anyone removed the stock shift handle? And if so would it be possible to use a custom shift knob IE: B&M Momo etc, and change the pushbutton switch to the new one. I've seen a few custom ones, pistol grip, grenade, and revolver cylinder but would like some more info before I start taking things apart to investigate.. Thanks
Old Mar 14, 2011 | 06:50 PM
squishead's Avatar
Here's mine pilot from pepboys. A little grinding to the inside of the grenade lever and playing with height adjustment on the lever and it works the shifter by pressing the grenade lever. The lever shaft is just a plastic rod that needs to be pushed down to shift. Remove the collar on the bottom of your stock shift knob by prying it downward. There's one torx screw hold the knob on , take that out and slide the knob off. Then you can see what you got to work with and go from there.
