Axle Install Problem
Old Oct 26, 2013 | 03:14 PM
Tylerm78's Avatar
Default Axle Install Problem
Installing a set of Nitro chromoly shafts today and can't get everything back together. I have evo sleeves and I think the new axles are too thick. I can't get the unit bearing all the way on. Anyone know if these 2 components will work together?
Old Oct 26, 2013 | 03:19 PM
cru9's Avatar
I do know the nitro axles won't work with the after market axle seals. I bought a set of the end if the tube seals and they would not work with my Nitro Axles. They are bigger than factory
Old Oct 26, 2013 | 04:01 PM
Tylerm78's Avatar
Difference in axles
Old Oct 26, 2013 | 04:25 PM
Tylerm78's Avatar
I go to put the stock axles back in and look at the gap. I don't see why it won't fit. I must be missing something.
Old Oct 26, 2013 | 05:31 PM
familytime's Avatar
JK Forum Regional Rep
Measure your axle shafts,by the picture it looks like your up graded shafts are longer
Old Oct 27, 2013 | 02:56 AM
OH9JK's Avatar
JK-Forum Ambassador
Do you have any extra sleeve sticking out?
Old Oct 27, 2013 | 03:59 AM
Invest2m4's Avatar
What spline axles are they? Upgraded 30 spline won't work with sleeves, except the nitro sleeves.
Old Oct 27, 2013 | 04:18 AM
Tylerm78's Avatar
They're just 27 spline. They engage in the ARB just fine. The shafts are the same length. There's more material on the yoke though. I'm going to attempt to trim sineish the EVO sleeve to get them in. Hope that works.
Old Nov 16, 2013 | 06:57 PM
Tylerm78's Avatar
Well got back to figuring this out. Trimmed off about a 1/4" of the EVO sleeve and they fit perfectly.
