Axle leaking
I had a slight leak on the passenger side. In the process of sleeving and installing C gussets I replaced both inner axle seals with synergy ones. Put it all back together and it leaked out the passenger side within 25 miles. Pulled it back apart and installed Mopar seals and the passenger side made it almost two days of wheeling and the driver has started leaking after the fourth day of wheeling. Any thoughts on why it leaks? The axle was bent a little according to camber reading but not to bad.
