Axle nut socket size needed -35 mm or 36mm?
There have been numerous posts about the socket needed for the axle nut - the majority say a 35mm is needed but there are also quite a number of posts that claim the 36mm is needed. Is this a case that 35 mm is the correct but a 36mm will work and is more common? I would think the correct answer is important because if it is the other way round and you have a 35mm socket and it is a 36 mm nut you are out of luck. So with all that - what is the correct socket?
