Axle question's
Axle question's
For the X model Jeeps, does anyone know the spline count on the front HP Dana 30 shafts?
Also.... Does anyone know for a fact if the rear Dana 44 in the X model Jeep is the same or different than the rear Dana 44 in the Rubicon?
I know there has been plenty of speculation, but has anyone tore into their axles and noted any differences?
Just wondering...
Thanks
Just wondering...
Thanks
The Rubicons have a D44 with 32 spline chromoly axles front and rear, the D30 and D44's in the Sahara and X have 30 spline axles.
Jeep JK Wrangler Axles:
* Front (X and Sahara)
o High Pinion 27 Spline Dana 30
* Rear (X and Sahara)
o Standard Cut 30 Spline Dana 44
o Standard Cut 27 Spline Dana 35 (2 Door without towing package)
* Front (Rubicon)
o High Pinion 32 Spline Dana 44
o Electric locker (open when switched off)
* Rear (Rubicon)
o Low Pinion 32 Spline Dana 44
o Electic locker (open when switched off)
* Front (Rubicon)
* Rear (Rubicon)
* Front (Rubicon)
* Rear (Rubicon)
* Front (Rubicon)
* Rear (Rubicon)
I seconded this information after some research
* Front (Rubicon)
* Rear (Rubicon)
* Front (Rubicon)
* Rear (Rubicon)
* Front (Rubicon)
* Rear (Rubicon)
* Front (Rubicon)
* Rear (Rubicon)
I need to correct some of this info for you:
Axles are not chromo they are SAE1040/1045.
Rubicon axle shafts:
Front Reverse Cut 44 : 30 spline inners and 32 spline outers
Rear 44: 32 spline
X, Shara, Sport axle shafts:
Front Reverse Cut 30: 27 spline inners and 32 spline outers
Rear 44 : 30 spline
Any questions, let me know.
Mike
