Axle question's
Old 01-29-2007, 06:17 PM
J33P JK's Avatar
Default Axle question's
For the X model Jeeps, does anyone know the spline count on the front HP Dana 30 shafts?
Also.... Does anyone know for a fact if the rear Dana 44 in the X model Jeep is the same or different than the rear Dana 44 in the Rubicon?
I know there has been plenty of speculation, but has anyone tore into their axles and noted any differences?
Just wondering...
Thanks
Old 01-29-2007, 09:06 PM
lwhitsell's Avatar
I'd like to know too. I have an X without the towing package but I don't know the specs.
Taggity.
Old 01-29-2007, 10:16 PM
RubiRed's Avatar
The Rubicons have a D44 with 32 spline chromoly axles front and rear, the D30 and D44's in the Sahara and X have 30 spline axles.
Jeep JK Wrangler Axles:
* Front (X and Sahara)
o High Pinion 27 Spline Dana 30
* Rear (X and Sahara)
o Standard Cut 30 Spline Dana 44
o Standard Cut 27 Spline Dana 35 (2 Door without towing package)
* Front (Rubicon)
o High Pinion 32 Spline Dana 44
o Electric locker (open when switched off)
* Rear (Rubicon)
o Low Pinion 32 Spline Dana 44
o Electic locker (open when switched off)
Old 01-30-2007, 04:27 AM
J33P JK's Avatar
Thanks!
Old 01-30-2007, 06:59 AM
IFSAR's Avatar
* Front (Rubicon)
* Rear (Rubicon)
This is good info. It looks like the front axle on the Rubicon has a Dana 44 center section and likely has 32 spline inner axle, but that is where the D44 ends from what I can tell. The front axle housing is puny compared to the rear housing and the outers (u-joints) look like Dana 30’s. There is no way the front knuckles are as beefy as many of the Dana 44’s I have seen on older pick-ups, etc. Therefore, what is the story on the knuckles……..are they Dana 30’s on the Rubi?
Old 01-30-2007, 03:06 PM
ericdewayne's Avatar
The door door X and Sahara models come with the D44 even without the tow package, as long as they have the manual tranny.
Old 03-08-2007, 02:32 PM
Sponsoring Vendor
Quadratec Rep
rubyred's Avatar
Default I seconded this information after some research
* Front (Rubicon)
* Rear (Rubicon)
Old 03-08-2007, 03:24 PM
IGOFSHN's Avatar
The 30 does have 32 spline outers. The inners are standard D30.
Old 03-17-2007, 07:37 AM
lwhitsell's Avatar
Yep. That explains my 2dr X with manual and no towing package. It has the
D44 rear.
Old 03-24-2007, 09:52 PM
Sponsoring Manufacturer
Superior Axle's Avatar
* Front (Rubicon)
* Rear (Rubicon)
Hey All,
I need to correct some of this info for you:
Axles are not chromo they are SAE1040/1045.
Rubicon axle shafts:
Front Reverse Cut 44 : 30 spline inners and 32 spline outers
Rear 44: 32 spline
X, Shara, Sport axle shafts:
Front Reverse Cut 30: 27 spline inners and 32 spline outers
Rear 44 : 30 spline
Any questions, let me know.
Mike
Quick Reply: Axle question's
