Axle shopping
Old Mar 27, 2012 | 12:19 PM
sneck's Avatar
Originally Posted by nthinuf
The inner shafts are different (27sp on the d30, 30sp on the d44), the outer shafts are the same (32sp). You can re-use the 32sp outer shafts, add new joints, and buy a set of used rubi 30sp inner shafts. But if you do this, you HAVE to use the expensive rubi e-locker.
(I do not know if you can run 35sp inner shafts/arb with the stock 32sp outers - but would suggest you go with 35sp inners/outers even if it is possible).
The PR comes with factory balljoints, That $550 you listed is for the upgrade to Dynatrac bj's? So, subtract the $550 from the pr44, or if you want the upgrades instead of factory, add that $550 to both setups.
Anther consideration is that you are quoting the PR-Unlimited housing. Subtract $200 for the non-caster corrected, thinner tubed version, which is closer to the stock rubi housing configuration. (this is assuming they are still making that version?) Caster/Pinion correction and thicker tubes is a great bonus, well worth the extra $200, but for a fair comparison you should use the non-unlimited one.
Also, for a used housing, VERIFY that it is straight!!!!!!! I was quoted 5-7 hours of labor for straightening my bent 30. (Add up that labor, plus sleeves/install, plus gussets/install, plus gears/install, and I was ordering a PR.)
My PR44-U was shipped to the shop for $4300. (including tax and freight). It came with gears and arb already set up, factory bj's, alloy inner shafts. Then we added new joints and re-used the stock d30 outer shafts/knuckles/brakes. I don't remember the cost of the joints, but figure $4350 or so for comparison purposes. (or $4150 for the non-unlimited housing).
I didn't realize they came with factory ball joints, thats good to know. I mean price wise, you're going to be looking at the more expensive housing, theres no point in going with a PR if you don't get the good version. however, I can certainly see how the costs can get closer and closer together. I guess what I need to do, since I've located a dana44 housing, is to call a local shop to see how much itll cost to gear it, and then get a quote for a pr44, and see what the true numbers I'm looking at are.
Is there a good way to verify if the shaft of a used housing is straight?
Old Mar 27, 2012 | 02:12 PM
nthinuf's Avatar
My shop used an alignment bar to check it. (gut the housing and slide the bar all the way in). I have seen posts where people suggest getting a good alignment done and judging it by the amount the Camber is out of spec - which won't help you with an empty housing, and I don't think it differentiates between bent housings and bent C's. I have also seen a pic of some type of a laser-level (or whatever it is called), that showed a bright red line of light along the outside of the housing. I am inclined to not trust this method.
So, find a shop with an alignment bar and have them slide it in. Very easy to see any bends at either end of the housing. (But again, that is for the housing only, it will not show bent C's).
And I agree on the unlimited housing vs the regular, just pointing it out in regards to a straight-up apples to apples comparison.
Also, I got mine about a year and a half ago, so it is possible that prices have changed some. It wouldn't be a bad idea to PM Scott (the Dynatrac rep here on this forum) and asking some questions. He is obviously biased toward the PR, but is a great source of info to help you make the decision.
http://dynatrac.com/products/jk/pro-rock44.html
The Standard Equipment section lists the factory balljoints. The heavy duty dynatrac bj's that you quoted are in the optional section.
Old Mar 27, 2012 | 02:33 PM
helnbk's Avatar
Why not build yourself some D60's from an old truck. Look at the 14 bolt for the rear, or high pinion D60 kingpin for the front. You pick those up cheap and build them for the same price as a D44, except they probably won't break on you again. You still have to buy gears and locker, but you would have to do the same on your D30/D44 at some point.
That's the route I would go.
Old Mar 27, 2012 | 03:18 PM
sneck's Avatar
heh, I actually found myself tempted to do that very thing. i mean sure, you need to spend the 3k or so on the conversion kit for the hubs, but some one tons would be sexy as hell. I think the only thing stopping me from doing that is the amount of time I would have to spend prepping for the conversion. but that type of project makes me wish I bought and built up a nice TJ. Seems fun, and pretty cheap too.
*edit* damn it, i knew there was a reason I had cl open looking at dana60s. a trek truss is only like, 300 bucks to go plug and play. still need to hub conversion though
