Axle support
Old Jun 25, 2013 | 07:21 PM
D_engel's Avatar
Originally Posted by kh202
Find someone who really knows what they're doing with a welder and maybe get it done for $50
^^^This as well. If you have pick up truck, pull the axle yourself and bring it to your welder. Much of the labor involved in welding a truss lies in the removal and reinstallation of the axle housing. Its a tedious job.
Old Jun 26, 2013 | 01:19 AM
kh202's Avatar
Heck we didn't even take my tires off lol
Old Jun 26, 2013 | 03:26 AM
JKred's Avatar
A truss is far superior to sleeves. I don't understand why everyone has such a hard on for axle sleeves. Adding a piece of tubing much thinner and with a significantly smaller OD than your axle tube is not going to do much.
About 66% increase in strength, fwiw.
Old Jun 26, 2013 | 04:06 AM
Patman's Avatar
For the truss or sleeves? How much strength are we looking at for the other one?
Old Jun 26, 2013 | 04:43 AM
familytime's Avatar
JK Forum Regional Rep
Truss,best way to goBut take it to a welder or you ruin your housing if not done correctly
Old Jun 26, 2013 | 01:21 PM
JKred's Avatar
For sleeves.
I haven't taken the time to run the numbers myself, but there was someone on another forum who did. I can't remember them off hand.
Just the sleeves number stands out in my head.
Old Jun 26, 2013 | 01:32 PM
BigSteve's Avatar
When you install sleeves you are essentially increasing the wall thickness of the axle tube itself, which does have its own merit and increase strength. Adding a truss will tie the axles together with the differential housing. What this does is when strain is put on one axle tube it will distribute some of that load to the differentail housing and the other axle tube, increasing strength that way. So what we are talking about here is increasing wall thickness and making the weak point either end of either axle tube (sleeves) or tying the entire axle housing together to help distribute localized load throughout the entire axle assembly (truss). ........ what just happened I blacked out a little!
Old Jun 26, 2013 | 02:09 PM
Rob 12B1P's Avatar
This thread inspired me to call my local 4x4 shop over lunch today and ask how much I could expect in labor for A) gussets and B) truss. (I can weld somewhat, but if the price is right I don't mind paying knowing that the work would be guaranteed)
I have the d30 and was told I should gusset and sleeve, and that a truss won't do anything other than look good
Is there any truth to that? I would think not, but then again I don't know everything.
Oh, and the quote was for "4-5 hours, so probably around $400 for the install"
4-5 hours is reasonable, if you skip around and don't let areas get too hot its a time consuming process. As far as trusses not working maybe that 4x4 shop has never properly installed one.
Old Jun 26, 2013 | 04:56 PM
D_engel's Avatar
Screw that haha. I'm no professional welder so my entire axle is coming out so I can make sure I do things right. I'm also installing the PJ backbone and I really want to take my time welding to the cast housing.
Now If I had a lift to put this thing on so I can get under my Jeep comfortably, maybe I'd attempt it with everything installed.
