Baaaaaaahhhh
Old Mar 7, 2010 | 07:35 PM
rozzman10's Avatar
Default Baaaaaaahhhh
ok... wheeled this weekend for first time in a while.. thank goodness.. but thats not the problem.. 2wd equals rear end lockin in hard and rollin on.. 4wd hi and lo equals one wheel in front.. one in rear.. CAN NOT get all four to hook up.. not even the back.. should the back not hook up even in 4wd???
Old Mar 7, 2010 | 07:39 PM
Robar's Avatar
You will require lockers to get both sides of the axles to turn at the same time.
Old Mar 7, 2010 | 07:42 PM
BlackNorthernJK's Avatar
get yourself some lockers
Old Mar 7, 2010 | 07:43 PM
Basic13's Avatar
Your not going to get any "lockup" with open differentials so I dont really know what you are talking about.
All 4wd hi/lo does is transfers power to all 4 wheels instead of just the rear-two.
If you have LSD then you might get "some" traction but it is not going to equate to "lockup".
Old Mar 7, 2010 | 07:50 PM
JPSquad's Avatar
I see some lockers in your future.
Hello Dave... 360-340-0282
http://www.northridge4x4.com
Old Mar 7, 2010 | 07:51 PM
tslewisz's Avatar
Rode with a buddy in his '09 yesterday. Tried a short steep snowy/muddy incline. It didn't make it but all four were spinning. The Brake Lock Differential worked as it should.
Old Mar 7, 2010 | 07:54 PM
rozzman10's Avatar
i have LSD.. and in just 2wd the back will hook up no matter what.. but when i go into 4wd the back wont hook up at all.. and yes.. lockers are in the future.. atleast in the rear.. because from riding four wheelers since i was 5 i know that even if only your rear end is locked you will go more places than someone with a LSD..
Old Mar 7, 2010 | 08:00 PM
GoodysGotaCuda's Avatar
If there is enough load on a lsd differential it will spin one wheel. It can only do so much since it is a limited slip. You are fighting the traction control in 2wd and 4-hi as well, unless you manually turned it completely off (not by hitting the button once either)
Old Mar 7, 2010 | 08:38 PM
ronjenx's Avatar
Originally Posted by 2k2wranglerx
the esp is usually enought to keep all 4 spinning. even in low it should still be working. the thing is it's not immediate. you have to let the wheels spin in order for it to work...
video evidence. this was open/open with no LSD (PS, check out the date hehehehe, that's why i was being such a baby, it was like 3 weeks old and at the time there weren't many others out, so it's not like there was an abundance of spare parts available. hell, i made the lift that is on it)
http://www.youtube.com/watch?v=wVN9RDAaZBI
http://www.youtube.com/watch?v=goheCXIVQ4U
That stuff is as slippery as ice!
Old Mar 7, 2010 | 09:48 PM
mud....look out for the tree
like the vid
