backspace ?
Old Apr 28, 2009 | 07:32 PM
Hoopa70's Avatar
Default backspace ?
with a 4" lift and 17x35x12.50 tires what would be a good backspace? the rims I am looking at have 4".. I don't want the tires to hang way out, and obviously I don't want rub either.. any thoughts?
Old Apr 28, 2009 | 07:42 PM
jayrav's Avatar
Usually 4.5 or less. If that is not enough you can get wheel spacers at 1.5"
Old Apr 28, 2009 | 09:38 PM
nthinuf's Avatar
Take a browse through the FAQ up top in this section:
https://www.jk-forum.com/forums/show...74&postcount=3
Q: What back spacing will I need on my wheels in order to clear 12.50 wide tires?
A: I would recommend that you do not exceed 4.75" of back spacing and even at that, you may still have some minor rubbing up front at a full turn. Also, I would recommend that you do not go any less than 3.75" as anything less would cause your tires to stick out very far past the fender flares. Any back spacing within this range should work out great.
Somewhere in the 4-4.5 range should give what you are looking for.
Old Apr 28, 2009 | 10:08 PM
RN M OVR's Avatar
If you do 4" they're going to stick out quite a bit. I would do 4.5" backspacing.
Old Apr 29, 2009 | 04:21 AM
Hoopa70's Avatar
Hmmm, thank you. Not sure they offer the rims i want in 4.5. Looks like they come in 4". All good info. thank you
edit: where does offset figure into this?
Old Apr 29, 2009 | 04:45 AM
greenamphibious's Avatar
then get wheels instead of rims
Old Apr 29, 2009 | 05:05 AM
bOLsAK=3's Avatar
Most everyone says 4.5" but I had 5" on my KMC Enduro's and they were just fine.
I'm not sure I would go with 4" but it's all just a matter of taste at that point.
Old Apr 29, 2009 | 05:18 AM
Have all 1200 posts since February been as informative as this one?
for the most part yes Have all 58 of yours been without using the search function? I mean this has been covered at least a couple times
Old Apr 29, 2009 | 06:43 AM
go here and read #3 in the third definition down..
http://www.urbandictionary.com/defin...erm=post+whore
(insert stupid emoticon here)
clever... you are getting the hang of it. I tried to find a word in that same dictionary for you but there was nothing that fit the definition of: Whiney ass crybaby that doesn't know how to use the search function and takes everything personal Oh well, keep it at 4.75 and less and you won't rub on the way to counseling
Old Apr 29, 2009 | 08:33 AM
I remember having to enlighten you once before on another thread, and because I am a nice person I will do it again here, so here goes:
The SEARCH function on forums typically suck. Sometimes it takes too long to wade through the one million posts that might have the word you want but no pertinent info. to a particular question. It can be a gigantic waste of time, and you definitely know about wasting time (I'm guessing your bosses time).That said, it is anyone's prerogative to ask a question, get and answer and effectively ADD to the SEARCH able knowledge base so the next person to search might find the answer without getting flamed for not using the "Search" function. Hmmm, I think that pretty well sums up the whole idea behind a public forum you tool.
which translates to you are a lazy retard?
[lastword]do a SEARCH for "I AM THE BOSS"
RESULTS: I can do wtf I want at work
stop being a fricken baby already... oh and thanks for helping me with my post count lol[/lastword]
