Backspacing
Old Feb 6, 2011 | 05:58 PM
TURTLECON's Avatar
Default Backspacing
If backspacing is the distance from the wheel edge to the mounting pad, then technically the number doesn't change when you add spacers, correct? Or is it the distance from the wheel edge to the axle plate?
Old Feb 6, 2011 | 05:59 PM
wayoflife's Avatar
JK-Forum Founder
this image is from the faq and should help you out
Old Feb 6, 2011 | 06:01 PM
nthinuf's Avatar
It doesn't change the backspacing of the wheel, but it affects the 'effective backspacing', as it moves the entire wheel/tire out further.
Old Feb 6, 2011 | 06:03 PM
TURTLECON's Avatar
Thanks for the prompt reply guys!! I totally get it now. The "effective" backspacing term kind of made it finally click hahaha
