Backspacing questions...
Old Dec 28, 2010 | 06:36 PM
Dale Gribble's Avatar
Default Backspacing questions...
Ok JK forum, I request your collective knowledge again
Finally got tires ordered for the GF for her 08' 4 door, now im torn,
I plan on buying Black Rock type D's to mount said 265/75/16 BFG All terrains on and was going to go 16x8 but now I dont know which backspace to go, 4.25 or 5.00
Please help and thanks
Old Dec 28, 2010 | 06:40 PM
Orangeav's Avatar
Go with 4.25. It will push the wheels out a bit farther for clearance if you ever go bigger. No clearance issues if you lift later. Pics in my album show 16x8 with 4.25 BS on ProComp 7069's
Old Dec 28, 2010 | 06:53 PM
Cool
Link to album?
Old Dec 28, 2010 | 07:18 PM
nthinuf's Avatar
If you don't have fender/tire coverage laws, the 4.25 BS would be the better choice. With that size tire, the 5 bs will work fine, but the 4.25 will allow you to go to a bigger tire in the future without having to buy another set of rims or add spacers.
Old Dec 28, 2010 | 09:30 PM
wayoflife's Avatar
JK-Forum Founder
as mentioned, 4.25 would be the better back spacing to go with but, they will cause your tires to stick out past your flares a bit. something to consider if you need to keep your tires inside your fenders.
Old Dec 29, 2010 | 04:11 AM
Orangeav's Avatar
Sorry for not attaching link, I don't know how to do that from the mobile app. Here are a couple pics for you. i'm running 285/75/16's on stock suspension...for now
ID:	113245Click image for larger version
ID:	113246Click image for larger version
ID:	113253Click image for larger version
Old Dec 29, 2010 | 05:05 AM
GentlemanFarmer's Avatar
Both backspacing will be fine. It just depends how much your JK wants to grow in the future and on how much you care about tire sticking out past the fenders. Personally I would go with the 5.00" because of the laws we have in QC. Furthermore having the tires inside the fenders help to keep the JK clean.
5.00" backspacing on an 8" wheel is 12mm offset.
This offset is similar to AEV pintler wheels that many uses with 35x12.5 tires and 2.5" lift. Actually pintlers are 5.15" backspacing but they publish 4.7" to fit common thinking that you need something between 3.75" to 4.75" backspacing.
That said the 5" backspacing whells would still support a small lift are quite large tires.
Old Dec 29, 2010 | 05:33 AM
tslewisz's Avatar
Actually, 16x8 7069's for a JK are listed as having 4.00" of backspace. Probably nitpicking, but since I have that wheel, too, it caught my eye.
http://www.4wd.com/productdetails.aspx?partId=55131
So, I agree with going 4.25 since I went a similar direction. However, I have a buddy with a 4" lift on his Unlimited running Rugged Ridge wheels (5" BS) and 35x12.50 tires and he's not having problems.
Old Dec 29, 2010 | 05:52 AM
Orangeav's Avatar
Good point! I forgot about that. You are correct about the 4" BS on the 7069's. I could swear that at the time I ordered these I had 3 options 4, 4.25, and 5. When I went back to look them up again I could only find 4" & 5, so I dbl checked my invoice and 4" it is. Only important to me bc I still have a spare tire to replace. Note: 4.25 will not stick out as far as the pics I posted...FYI to those who struggled with this concept like I did at first... BS vs. Offset and so on.
Old Dec 29, 2010 | 05:56 AM
tslewisz's Avatar
My head explodes when we talk about offset. Mostly because it's usually expressed in millimeters and we talk about everything else in inches.
