Ball joint opinions
Old Aug 30, 2012 | 04:56 PM
c17loadmaster's Avatar
Thanks guys. New ball joints going in next week!
Old Aug 30, 2012 | 06:53 PM
Mhare's Avatar
My moog ball joints have a lifetime warranty. I can change them myself. So I couldn't justify paying that much for pro steer.
Old Sep 7, 2012 | 06:31 PM
I must say that 50k on factory ball joints is toooooooo much!
When I replaced my ball joints today I saw the craptory products up close. When I removed the factory upper ball joints, they LITERALY came apart in my hand! All 5 pieces. I am feeling lucky that didn't happen on the road or trail.
Old Sep 7, 2012 | 06:39 PM
jeeeep's Avatar
i'm lucky mine have lasted close to 60k miles..but after my last weekend check, i think it's time to replace....
Old Sep 8, 2012 | 08:55 AM
After the ball joint install I find myself with a weird kinda bump steer. Almost like the jk wants to " track" down the road. Any ideas? Maybe I just need an alignment now.
Old Sep 8, 2012 | 09:22 AM
Mgimelli's Avatar
Alignment is always a good place to start. But check that everything is tight. Loose bolts could be an issue.
Old Sep 8, 2012 | 11:31 AM
nvertflyer's Avatar
may be torque settings...i believe the uppers are 70 ft lbs and the lowers 110...there is also a torque step up procedure...you sure got a lot of miles out of those stockers....i barely got 4000 out of the stock set i put on my front axle before going to the pro steers...
Old Sep 8, 2012 | 12:36 PM
I double checked the torque settings per manufacturer directions. I have not seen anything about a torque " step up" procedure. The steering knuckles feel tight ( compared to before) which is expected. It is just that the jk seems to want to wander all over the road now and I get a lot of feedback in the steering wheel. I have Tom" actively counter steer in either direction to stay in my lane.
Old Sep 25, 2012 | 07:05 AM
dellpjJK's Avatar
Default 90+
My dealer said I need to replace these but wants to charge an arm and a leg. I'm going to do it myself. However, I've gotten over 90K out of mine. Is this really that common to replace or something that "should" be done, but most people don't do?
Old Oct 13, 2012 | 03:50 PM
Rhino's Avatar
I'm wondering if I should be shocked that I'm at 80k and haven't replaced them yet. I have been getting worse and worse deathwobble lately and checked them, sure enough, they look like they're shot.
