Ball Joints AGAIN
Old Nov 9, 2008 | 09:57 AM
0311sgt's Avatar
Default Ball Joints AGAIN
Does anyone know who, if any, makes aftermarket balljoints for the JK? both sides are bad. replaced both before 12,000 miles and now again at 21,000 miles. dealer replaced the first time under warranty, but due to trail use and lift is reluctant to warranty again. Searched internet for some and came up empty handed. any help would be greatly appreciated.
07 JK Unlimited
3 inch BDS suspension lift
33x11.5x16
JKS Quicker Disconnects
Warrior Products Tube Doors
Mopar Off Road Rear Bumper
Oil Pan Tranny Skid Plate by SkidRow
Custom Front Winch Bumper by RoundStar OffRoad
Skyjacker Adjustable Rear Track Bar
Skyjacker Brake Line Extenders
Rock Krawler Adjustable Front Lower Control Arms
And Plenty of "CHARACTER" From rocks and Trees
“A bad day on the trail, is better than good day in Prison!”
^ YCP 4X4 motto ^
Old Nov 9, 2008 | 06:31 PM
SB08JK's Avatar
Your tires are barely any larger than stock. I would try to push the issue a little harder, you may get lucky with another dealer.
If push comes to shove, the dealer will win the argument, but maybe with a different dealer, perhaps a mod friendly one, you may get lucky.
Good luck!
Old Nov 9, 2008 | 09:46 PM
chuck45's Avatar
Why are ball joints on JK's going out so soon? Is here any PM we can do to prevent it from happening? Is the only source for replacements the dealer? If so can they be modified to be greasable? I hate problems like this; or maybe I should say I hate bean-counters that are at the root of stuff like this.
Old Nov 10, 2008 | 06:59 AM
hiontach's Avatar
i don't think everyone's ball joints are giving out, just a small, small number of owners. there is no PM on most of your suspension parts because most of them are sealed.
i wouldn't recommend modification to those parts as PM just because the likelihood of doing it wrong may result in even faster wear.
Old Nov 10, 2008 | 07:11 AM
RedneckJeep's Avatar
GM had this same problem with a very high number of Chevrolet and GMC full size trucks from 1988 to about 1993 or so. The cause was moisture contamination from a poor seal.....AND non geasable ball joints. I know the ball joints on my Jeep are non greasable, as are probably the rest of the JKs. If moisture gets in a ball joint and cannot be forced out by new grease, rust will kill a ball joint in short order. I've thought about drilling a hole in the center of the back of all of mine and threading in a zerk fitting. I've done it alot before and it works.
Old Nov 10, 2008 | 03:46 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Try these out, Rock crawler makes them, they are heavy duty. You need to buy the ball joints separately though.
http://www.4wd.com/productdetails.as...0&partID=41378
make heavy duty tie rod too
http://www.4wd.com/productdetails.as...0&partID=41379
I know someone on the forum has them because they bent the stock a couple times.
Old Nov 10, 2008 | 04:44 PM
chuck45's Avatar
I have the tie rod on order from RockCrawler and will use the specified Moog 3/4 (or are they 1 ton?) ball joints. A bit down the road I'll probably do the drag link too.
However perhaps we have a misunderstanding here. I thought the ball joints we were discussing are the upper and lower ball joints on the "C" knuckle on the axle; not the balljoints at the ends of the drag link and tie rod. Replacing those is no big chore and of course when you upgrade to the Moogs you get greasable ball joints. Replacing the ball joints on the C's is a bit more involved and the question would remain; are there quality aftermarket units that are geasable available.
Old Nov 10, 2008 | 07:01 PM
Here are some. http://www.quadratec.com/products/56100_0002.htm I'm sure you can call to get specifics.
Old Nov 10, 2008 | 08:14 PM
0311sgt's Avatar
i dont know why i couldnt find those on quadratec...but thank you, i am going to call them in the morning and talk to them thank you again for the information
Old Nov 10, 2008 | 08:19 PM
chuck45's Avatar
Thanks for posting that. I wonder what brand they are? It doesn't looklike they have grease zerks. Can zerks be added?
