Ball joints.... Grrrr
So I may need some feed back on what others have done with creative issues with removing their ball joints. When I tried pressing out the top ball, the inner shaft pushed right through the back part of the joint leaving the knuckle packed with just the steel outer casing. Make sense?
Now I cant press out that outer steel ring!!! I'm sure (hopefully) this has happened to someone who can share creative ways to get it out.
I'll take a pic a minute... I worked on it for hours yesterday and am about to attack it again....
Also, the passenger side axle shaft won't budge. Grrrrr.
Is welding an option? Looks like it's already been cut. Obviously penetrating fluid also. Have you tapped the sides with a hammer to see if you can break it loose? Is heat an option? Heat up the outside then tap away.
What's hung up with the passenger shaft? I've used a gear puller to get the hub off of the shaft then the shaft slides right out.
Is welding an option? Looks like it's already been cut. Obviously penetrating fluid also. Have you tapped the sides with a hammer to see if you can break it loose? Is heat an option? Heat up the outside then tap away. What's hung up with the passenger shaft? I've used a gear puller to get the hub off of the shaft then the shaft slides right out.
Yep, welding on gussets so can weld if needed...
I'll try to heat the inside of the ball joint... I smacked it every way possible with a chisel, hammer, wedge etc... I tried cutting it to maybe break the bond but no go.
Maybe weld a cap to the old bj so you can press it out or see about welding a nut on there to see about sharp twists to break the bond- assuming there are no grooves that the joint slips into.
From what your describing, it sounds like it's now hollowed out. Can you fit a sawsall in there, maybe cut a relief, taking care not co cut into the knuckle? From there maybe you can hammer and chisel it until it breaks out.
