Battery Issue?
I am not sure what is the issue here but hope someone can help.
At random my Jeep will not start (2012). No power at all. I get out wiggle the negative batt terminal and magic power and starts up. The terninals are completly secure to the battery. Its under warranty but I would like to avoid that hassle if possible
Thoughts? I have a winch and ARB compressor installed to the battery as well.
Thanks!
Thanks!
I'm not sure if my problem is caused by what you're experiencing but I've been having a problem with losing all my electronics.
When I have my cruise control on, for a split second my cruise shuts off, my speedo goes to zero then back up, radio shuts off then back on, and my traction control light comes on. My cruise will either not shut off or turn on, and my traction control light stays on. Most of the time, when I shut the engine off, then start back up everything seems to work fine. One day, the trac light stayed on even when I shut the engine off. When I came back later to start it, it wouldn't start. I had to jump start it.
I have no clue what's causing it. I thought it was the bullydog unit, so I unplugged it on my last trip to Columbus, but I had the same problem. I have a bunch of LED's running to the battery, and my headlights, fogs and light bar are all hooked up to the battery too.
I had all these problems. 2012 also with 25K miles. The dealer replaced the TIPM and WCM but it still had the electrical gremlins. One day it wouldn't even turn over. They replaced battery and all has been fine for the past month.
