BB install help!!!
Old Jan 19, 2011 | 11:55 AM
medic_23387's Avatar
Default BB install help!!!
I bout a PROTHANE 2" coil spacer lift with extended bump stops for my 07 Sahara. It comes with no instructions and the company said they do not have any either. So any help would be great.
Old Jan 19, 2011 | 11:58 AM
Pluke the 2's Avatar
lol.
http://project-jk.com/jeep-jk/jeep-jk-write-ups
Old Jan 19, 2011 | 12:04 PM
Originally Posted by Pluke the 2
I have look at that link. The only thing i can find close is the TF 2.5in lift. My bump stops look way diff and and I do not have shock extenders. Are all about the same could I follow that guide?
Old Jan 19, 2011 | 12:06 PM
nthinuf's Avatar
Yep, use any of the suspension write-ups. They all use basically the same steps. Jack it up, disconnect stuff, pull the coil out, put the spacer on top and re-install. The front bumpstops go inside the coils, so be sure to remember that step.
Old Jan 19, 2011 | 12:08 PM
_J__C_'s Avatar
The spacer should install the same.
Old Jan 19, 2011 | 12:10 PM
Will my old bump stop go into my new one like on the guide? Which spacers go in the front and which go in the back. I am assuming the taller ones go in the front.
Old Jan 19, 2011 | 12:13 PM
sorry for all the stupid questions I thought it would at least come with some instructions. Do all coil spring lift use the old spacer as well?
nthinuf's Avatar
Yes, taller in front - that gets rid of the 'stock' front rake.
Depends on whether you got upper or lower bumpstops. Uppers you may need some grease and a jack to get them in place, lowers you will need to drill and tap a hole. You can find pics and steps for both in those write-ups.
Old Jan 19, 2011 | 12:19 PM
Here is a pic of the parts I think they are upper.
Old Jan 19, 2011 | 12:21 PM
_J__C_'s Avatar
Had to retype this, you posted a pic while I was typing.
The two with the "cone" tops go in the rear, the other two in the front. Put the rubber isolator that's above the stock spring goes under the spacer, and on top of the spring.
