BDS Lift
Old Sep 9, 2008 | 12:54 PM
tprice1985's Avatar
Default BDS Lift
Is there anyone on here running the 3" BDS lift? I am looking at it at a local shop where they say it will run 37" tires.
Old Sep 9, 2008 | 12:58 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Here yah go tprice several folks are running it on the below link
https://www.jk-forum.com/forums/modified-jk-tech-2/bds-lift-vs-teraflex-54153/
hope that will help yah!
Old Sep 9, 2008 | 12:59 PM
FuLcRuM's Avatar
They are lieing.
I've "heard" it is an actual 3" of lift vs. the Teraflex slightly more then 3" lift so unless you have flat fenders also it's not gonna clear.
Old Sep 9, 2008 | 01:08 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by FuLcRuM
They are lieing.
what he said - teraflex lifts run on the high side and their 3" lift is easily more like 4" and their 4" lift is more like most 6" lifts out there.
Old Sep 9, 2008 | 01:13 PM
gogrlgo's Avatar
They are wrong! Ive got the BDS 6.5" with 37s. and it will rub.
Not the best angle but..... Before I chopped the fenders....
The yellow jeep is running a 3"BDS with 35s...no rubbing
Old Sep 9, 2008 | 01:31 PM
wayoflife's Avatar
JK-Forum Founder
i've got nothing to really add here except for the fact that your jeep looks great
Old Sep 9, 2008 | 01:53 PM
wrnglrguy's Avatar
I run the BDS 3" lift with 35" tires. I am getting ready to swap to their 4" springs because at full flex, I have a little bit of rub on the fenders. The BDS 3" is EXACTLY 3" of lift, whereas other 3" lifts actually give you over that. I would not run 37" tires on it.
Old Sep 9, 2008 | 02:37 PM
TeraFlex's Avatar
Sponsoring Manufacturer
We've got the red Unlimited running around with a 3" LA kit and 37's. Sorry it's not here for me to take pics. Wait a sec......
That's my yellow JK with a 4" LA kit and 37's.
Old Sep 9, 2008 | 02:41 PM
Ewok's Avatar
BDS 3" will not run 37's maybe with Flat Fenders the Teraflex 3" can, but if you want 37's go with the Tera 4"!
Old Sep 9, 2008 | 06:38 PM
style_front's Avatar
So whats the difference between a 3 inch kit that rubs and one that doesn't rub, bumpstops? A lift will not change the pinch seems (the typical rub spot on jk's) so by saying one rubs and the other doesn't just means that one is missing bump stops, correct?
Unless your cuttin and weldin fender wells there's not much a lift can do to allow more stuffage, unless there is some thing I'm missing here.......
