Bds suspensions, yay or nay...??
Old Dec 20, 2013 | 11:12 AM
  #31
MtraXX's Avatar
Originally Posted by Jkforlife
i own a 2 door with an AEV 2.5 in lift, super smooth, you dont need newer control arms, just buy the geometry correction kit which will lower control arms to make it alot smoother, i checked out he other companies and no other company gave such a full comprehensive kit like aev, definately well worth the money if you spend anywhere more then 50% on the road, just my 2 cents
Careful with not upgrading those stock CA's, especially if you plan on wheeling.... Stockers don't take a rock beating very well.
Old Dec 20, 2013 | 12:05 PM
  #32
ronixwrangler's Avatar
thanks everyone, i appreciate all of yalls input.
Old Dec 20, 2013 | 06:06 PM
  #33
JcrOffroad's Avatar
Sponsoring Manufacturer
We run BDS on all of our Jeeps and also install BDS regularly for our customers. They are great riding lifts, awesome unmatched warranty and I have problem recommending them!
Old Dec 20, 2013 | 06:15 PM
  #34
imped4now's Avatar
BDS has highly overrated parts that do just fine on street queens. Start exposing parts such as their control arm bushings to high amounts of travel and you'll find the flaws. Take a look at them on a component basis and you'll see why companies like Currie and Metalcloak are so much better.
Old Dec 20, 2013 | 06:20 PM
  #35
Flexer07's Avatar
Originally Posted by ronixwrangler
Thanks! I'm def leaning towards the rk
rock krawler is a great choice. Don't regret mine.
Old Dec 20, 2013 | 06:26 PM
  #36
robsjeep9's Avatar
JK-Forum Ambassador
Why do you "have problem" recommending them? Lol Freudian slip perhaps
Old Dec 20, 2013 | 06:39 PM
  #37
LidLess07X's Avatar
BDS's "no questions asked warranty" is BS. I will never buy from them again.
I had lift done at my Jeep dealer. Within the first week one of my sway bar links broke. I called BDS and explained the situation. I asked them to ship me a new one and I would just swap it out. No Deal!
They informed me that I would have to take it back to the dealer (a three hour round trip and eight dollars in tolls or, 24 dollars in tolls if someone has to take me there and bring me back.)
I pleaded my case but they would not budge. I took it in and had it replaced no charge. One week later the other side broke. I called again and was informed I would have to go through the hassle of returning it to the dealer again. My response was " no problem, I'll just buy better quality ones from JKS and never buy your products again.
So much for their "no questions asked warranty"
Old Dec 20, 2013 | 08:54 PM
  #38
MtraXX's Avatar
Definitely not a "street queen" here! I'm in Maryland so am exposed to winter salt, summer heat, and wheel often with have zero issues... So easy on your comments!
Old Dec 20, 2013 | 08:58 PM
  #39
MtraXX's Avatar
Hmmmm.... Not saying you didn't have issues but what if you installed the lift on your own? Then you wouldn't have a dealer to deal with and maybe they questioned the installation?
Old Dec 20, 2013 | 10:21 PM
  #40
kjeeper10's Avatar
Vet Army
Shocks will make or break your ride.
You do not necessarily need control arms with 2.5" Install the lift and drive the jeep. Low caster will create a loose steering feel. Drop brackets will also help but with some clearance loss (if a concern)
TF coils won't give you a crap ton of lift witch is nice. With a lot of weight this maybe a issue.
I do recommend a front track bar. The TF monster is a absolute beast and easy to install and adjust.
Shocks.. 4 door Rancho 9000 or 5100
For a 2 door Rancho 9000's
I usually Recommend for a new jeeper starting off/light to moderate wheeling and no weight.
- Teraflex 2.5 w/0 shocks or extensions (gives you the rear axle bracket for the track bar)
- Rancho 9000 shocks (29xl front, 30xl rear)
- front adjustable track bar (your choice but I like my Teraflex)
- front disconnects if needed
- (optional) Northridge 9/16 grade 8 bolt kit replaces all lower CA's and both track bar bolts.
