Bead locks
Old Jan 10, 2016 | 05:36 AM
  #131
nhk19's Avatar
Originally Posted by Wrangeler X
Yea I got a couple cans of professionally mixed paint (color match) with hardener from an auto paint supply store. And white primer. You have to paint yellow over white. Cost me about 75 in paint and primer. Could have powder coated for 100-125 but it wouldn't have matched and I wouldn't be able to touch it up. Now I can touch it up with color matched paint if I so choose. I actually got a scar while driving down the highway in one already. I'll go ahead and touch that one up to keep it from spreading. Northridge 4x4
I'll probably leave mine as is. If I do paint I'll take your advice on using color matched paint. Thanks. Again...I think yours looks great!
Old Jan 11, 2016 | 04:52 AM
  #132
SoK66's Avatar
Dan Mick just posted a shot of his refreshed Racelines bead locks on FB. He had them cleaned, powdered silver, then clear over that. Really look great.
Old Jan 15, 2016 | 12:23 PM
  #133
mhockey9090's Avatar
Vet Army
Walked into Discount Tire with the beadlocks on the Jeep already, walked out with them balanced for $40. No more shaking at 45 mph and up. Now my alignment is a different issue. hahaha
Old Jan 15, 2016 | 12:31 PM
  #134
bryanluu's Avatar
Originally Posted by SHOELESS
ATX Slabs and a good work stool. Air ratchet to seat them and then 3 times around with the Snap On digital torque wrench. Easier than you think, just a little time consuming....
I personally would never recommend ANYBODY to use an air ratchet on any beadlocks. The risk of cross threading and stripping the threads on the wheels highly out weighs the little time you save. Just do it the right way by hand and use some anti-seize and you'll be golden.
Old Jan 15, 2016 | 12:39 PM
  #135
Vet Army
exactly how I did mine. Hand tighten with the 1/2 socket and extension, then got them a little snug with a ratchet, and finally torqued. I had anti-seize all over my hands by time i was done
Old Jan 15, 2016 | 06:11 PM
  #136
HDGasser's Avatar
Check with the mfg before you start lathering things up in anti seize, some require they get installed dry.
Old Jan 15, 2016 | 07:03 PM
  #137
Vet Army
Talked to them before I did anything. They also have a video on youtube that mentions anti-sieze.
Old Jan 16, 2016 | 04:53 AM
  #138
SHOELESS's Avatar
I did not say tighten them with an air ratchet just run the down. Watch the video of Mel @ ORE installing the lock rings on a Slab. I'm pretty sure he has done it a few times......
Old Jan 16, 2016 | 03:00 PM
  #139
bryanluu's Avatar
I know that is what you meant. It only takes a few full turns to properly torque a bolt on a beadlocks rings. How many RPMs does an air ratchet spin at? Enough to accidentally strip or over tighten your bolts. It's not up to me to tell you how to mount tires on beadlocks, I'm just trying to save someone's wheel from getting ruined.
Old Jan 16, 2016 | 05:34 PM
  #140
Vet Army
I guess you can say mine were broken in a bit today. Had them aired down to 6 psi without any issues. I will go down to 5 next weekend and probably stay there.
Time to grab the spray paint
