bent axle question
Old Sep 29, 2012 | 11:13 AM
themoneyshot's Avatar
Default bent axle question
when someone has a bent axle does that mean it has a dent? or does the tube bend? if the latter does it normally bend at the diff? and most importantly was the repair?
Old Sep 29, 2012 | 11:43 AM
dcharge74's Avatar
It's the axle tube itself that bends. Not sure if it's at the pumpkin or not, but does it really matter? I believe the only realistic fix is a new axle housing. All the internals should be able to be re-used.
Old Sep 29, 2012 | 12:02 PM
Freewill's Avatar
Unless it is the axle shaft that is bent. In that case the housing could be fine and the shaft(s) needs to be replaced.
A bent housing means the steering won't align; a bent shaft means the wheel is wobbling. Worst case: both are bent.
Old Oct 1, 2012 | 07:03 AM
Dynatrac's Avatar
Sponsoring Manufacturer
Are you asking about front or rear? Were you told you have a bent axle shaft or housing? What is the problem/symptom?
