Bent front axle
Old Sep 6, 2007 | 07:34 PM
00pumpkin's Avatar
Originally Posted by evolution
Every one has had 35s or larger tires its just the bigger tires and wider rims give it more stess. Gusseting up the C's is the only fixs I see .
Did any of them have really small backspacing or were using wheel spacers? This puts alot of stress on them.....
Old Sep 6, 2007 | 08:59 PM
Evolution's Avatar
Sponsoring Vendor
I have not seen any bent with stock rims only with standad aftermarket 4 inch back space and also with stock rims with spacers.
Wow there is a lot of gusset on that Baja axle it looks very strong nice work.
I think for the standerd off roader just gusseting up the top and bottom of the C would be plenty
Puddlz Nice air!!! Warranty???
Old Sep 6, 2007 | 09:42 PM
ROKLIMO's Avatar
Originally Posted by dougolupski
Thats disturbing since 35's arn't new to jeeps. The TJ D30 was able to with stand 35's with axle shaft and ujoint upgrades. Maybe Chrysler is having metal issues.
Maybe Dana is having issues...Chrysler doesn't make the axles
Old Sep 7, 2007 | 06:50 AM
freshjk's Avatar
I recently just bent my d30 and broke a lower control arm braket running 35's on a tera 4" lift. ...not very happy!!!
Old Sep 7, 2007 | 09:41 AM
Evolution's Avatar
Sponsoring Vendor
Ya we have had 3 diferent lower control arms 3 diferent kits and tire size
both 44s and 30s
all have been passenger side
Old Sep 7, 2007 | 10:17 AM
hemi's Avatar
How many people out there have bent front axle housings
(Inner Steering Nuckle Cs)
Have you notice that the front wheels look like thay are in at the top.
Like to much Camber
I have seen a few come threw the shop was just wondering if any one else is seeing it ?
if my wheels are closer in at the top it means my axle is bent because it sure looks like that
Old Sep 7, 2007 | 10:57 AM
greggradwohl's Avatar
both 44s and 30s
Do you think this is from a "bad batch"? Or do you expect this to be deficiency with all JKs?
Old Sep 7, 2007 | 12:07 PM
Jake_Blues's Avatar
You should have SOME camber, but not much. I think it's something like .25 degrees, so the top of the wheel should be tilted in about 1/8th of an inch or so. That would be tough to spot with the naked eye. If you put a level up to your tires, they should be pretty damn close to vertical.
-E
Old Sep 7, 2007 | 12:37 PM
hemi's Avatar
-E
thanks, i'llcheck that tonight
Old Sep 7, 2007 | 12:44 PM
Evolution's Avatar
Sponsoring Vendor
Not trying to get anyone to (bite) was wondering if everyone was having this issue or just a few
We are haveing these gussets laser cut but it will be a weld .
